What center stand
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by hatcher, Nov 15, 2004.
  1. hatcher
    hatcher
    As is common with many home cinemas in these forums, I've use the Oppili from Ikea to house all the AV kit at the front of the room. This means the center channel sits on it.
    [​IMG]
    I seem to get a lot of resonances from the unit when I turn the volume up as it's a pretty light peice of furniture. This ruins an otherwise pretty respectable (IMHO) setup. Don't get any problems from the other four speakers and sub as they are all spiked floorstanders.
    Has anyone got any ideas about how I can mount this speaker so that it's isolated. I don't think a wall mount would be any better as it's likely to just vibrate the stud wall. I was wondering if a short spiked stand sitting on the unit would work.
    Any ideas?
    Hatcher
  2. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    OT
    I wish I could get some of those Bertby wall cabinets - they've been withdrawn 'cos of poor spec screws. There's a product recall notice on the Ikea site you may want to check (I think they'll send out new screws or something...). HTH
  3. hatcher
    hatcher
    I saw that and enquired last time I was there. The only problem with it was that the two screws included that are to be used to hold it to the wall were not big enough and when used some units had fallen off people's walls. I didn't use them anyway so it wasn't an issue. It's a shame if they are not selling them for that reason as it's pretty easy to rectify.
  4. Tenex
    Tenex
    Mar 2, 2003
    7,632
    +1,063
    exactly, that's the ONLY reason they won't sell the ****** things.
    Of course it does lead to the hilarious situation where it's probably the ONLY product not out of stock in the warehouse 'cos they won't sell them.....
  5. aquapiranha
    aquapiranha
  6. hatcher
    hatcher
    Thanks Aqua.
    Nice equipment rack but I really only wanted to isolate the center speaker. I'm quite happy with the oppili housing the electronics. It's an option though.
    Hatcher
  7. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    I know KEF do a centre stand for the reference range... Maybe that could be of some use?
    I had a similar problem with my centre speaker. I managed to reduce the problem by using sorbothane feet.
    Maybe you could experiment with some blu-tac first before laying out any money. Another thing I have heard people using are those isolation platforms or the feet. I can't say whether they will work but worth experimenting with if you can. Anything goes in this game!
  8. hatcher
    hatcher
    Thanks I'll look into Kef's stands. I've heard good things about sorbothane feet from the old 'get the most out of your turntable' days - where did you get yours from?
  9. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    Hi Hatcher,
    I got mine from my local dealer but I think they are readily available online. I found www.britishaudio.co.uk to be very good for all sorts of quirky little things that you must have! They have a set of 3 for £12 on there.
    Seriously though, try some blu-tac first to see if it makes any difference before spending the money... Also, if at all possible, have you considered experimenting with maybe a marble slab or a paving slab under the speaker?
    If nothing else, it's a good excuse to play at high volume! :D
  10. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Definitely try blue tack if you havn't already. You could even decouple the speaker by placing a bit of wood between it and the equipment rack, obviously with some blue tack between both. Cheap to try at least.
  11. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Get yourself a pack of Auralex MoPads. I use them under my Linn Trikan to isolate it from the glass shelf of my TV stand very effectively. Conveninently they can be set at a variety of angles up or down to ensure your centre is on-axis. Details here, available from several suppliers in the UK.
  12. flamingoboo
    flamingoboo
    Jun 4, 2004
    125
    +3
    I have had very good results using nordost pulsar points, not cheap, but very effective and soo soo sexy.
  13. hatcher
    hatcher
    Thanks for the ideas guys. I'll look into all of them.
    cheers,
    Hatcher
  14. vanwel
    vanwel
    I'm also searching for a center stand. I found the VTI stand and the B&W stand. However, they're not tall enough (11 inches or so and I need about 15) and above that the B&W stand is discontinued.
    I could not find the KEF stand.
    Can anybody tell me if there are more centerstands like these, only taller?
    I'm searching for almost a year now!
    Thanks!
  15. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
  16. JTinKaz
    JTinKaz
    Nov 20, 2004
    27
    Northern Ireland
    B&W have a new Center speaker stand out in Feb 05. See attachment.
