What Capture Card?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Cliff, Dec 12, 2001.
  1. Cliff
    Cliff
    Mar 17, 2001
    6,075
    167
    Kent & Accra
    +3,424
    I want to transfer video from my oldish Sony Hi8 machine and use editing software. I am currently using Videowave and Adobe premier.
    What is the best and cheapest way to go about this.
    I have looked at the Pinnacle Studio10plus. This is about £135 but outputs video in Motion JPEG. (That doesn't sound like a common standard to me.)
    I can buy an MPEG encoder for more money - but do I want unedited video to me MPEG?
    I can buy something like the Dazzle Hollywood bridge that outputs in the DV format- which seems like the best - but this unit costs a lot.
    Advive please?
  2. mcwill
    mcwill
    Go for the Dazzle DV-Bridge
    I have just picked one up from Insight - £228 inc Vat
    I used to struggle capturing largish avi files hoping not to drop too many frames or would the sound be in sync. All this is now a thing of the past - 720x576 DV-Avis are now streamed to my hard drive whilst I'm using the computer for other things :)
    The quality is also very good I run an S-Video lead from my Sky+ box and the resultant SVCDs are very good.
    Regards,
    Iain
  3. Arthur.S
    Arthur.S
  4. Cliff
    Cliff
    Mar 17, 2001
    6,075
    167
    Kent & Accra
    +3,424
    Thanks Iain and Arthur,
    I'll try posting on that forum- they have a lot of interesting stuff on video there. Just over £200 is still quite a bit of money for the DV Bridge, but I guess it is a fairly specialist product.
    What about MJPEG from Pinnicle? Can this be imported into Premier? (or should I not waste my money and time like I did buying a Dazzle Video creator 80)
    Cliff
  5. Kevin Priestley
    Kevin Priestley
    I dont know if this is of any help but i have to agree with mcwill on the Hollywood Bridge. I had been using the capture element of my video card, (ATI Rage Fury pro) and getting so-so results.
    But decided to go for the Hollywood bridge, and I must say the results are excent. I use it with my Raptor DV card and it will capture video for as long as I have hard drive space without frame drops and the picture quaity is ace.
    I now its a lot but it is the right bit of kit to do the job.
