What can Neromix do?
Discussion in 'Headphones, Earphones & Portable Music' started by chris_h, May 3, 2005.
  1. chris_h
    chris_h
    Apr 24, 2005
    77
    I am looking to do the following things in particular:
    - record analogue audio onto PC and then burn to CD
    - record sections of 2 hour radio shows i have downloaded onto CD (i was told that nero express cannot cope with this and does not allow you to choose a segment)
    - clip the first second or 2 of a file where it is blank so that music starts on the first beat (i dj and this makes things less hassle!)
    i realise the 2nd and 3rd points are basically the same but the 3rd point requires more accurate "clipping".
    Before I get it, can neromix do all these things?? Or can someone recommend another package (and where i would find it)?
    :lease:
