Hello there,
I'm hoping you guys would be able to suggest a reasonably priced (I'm not a massive videophile) splitter / switchbox to fit in the attached image.
I basically have 2 TV's back to back.... and have multiple sources. I have a 3 way HDMI switchbox from ebay (£15) which works a treat with all devices on one TV. However I would now like to select which TV it goes to as well. So I'm thinking a splitter / switchbox is the next in the chain.
Do you guys have any recommendations? It will be sending a Sky signal, so must be HDCP compliant...which begs another question, can you pass HDCP through multiple switchboxes/splitters?
Apologies for the crude illustration!
