What can I do and how do it (chipped XBOX)
Discussion in 'Xbox Forums' started by dUnKle, Aug 12, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,382
    I now have my XBOX chipped and working (thanks in a large way to help on here) and I have also installed a Hard Drive of 120GB which has loads of apps and emulators etc on it
    However I am probably more overwhelmed than ever and wander if someone can (in simplest of terms) explain what I can now do with my XBOX.
    Things I am currently confused about are .....................
    <1> Playing XBOX games from the Hard Drive. Just installed Driver 3 onto the HD but it will not run - just says loading - is this a known problem.
    <2> How do I put more things on the XBOX? - I have my PC and XBOX connected to a DLINK router. I assume some sort of networ etc needs to be set up which will allow me to browse my XBOX and drag files to it. Is this correct? How would I do this?
    <3> Media Centre. It looks lovely and I have managed to get my local weather. It even tells me its raining so no need to open curtians. But what else can I do with it? I installed Kill Bill 2 onto the HD but when I want to play it it only lists it as .VOB files and plays each one seperatly. I was under the impression you could play the whole film just by selecting its time or even an icon.
    <4> Emulators. Have Mame, Snes, N64 and a Genisis one. What others are worth looking for? Can you get ones for C64 or Amiga?
    Again I apologise for all the questions but hope someone can help
  2. merrick
    merrick
    Jul 6, 2002
    Hey Dunc
    1) Go into evo-x settings and disable the In game reset, all the latest bios's have a hardware IGR and sometimes the evo-x IGR conflicts and can stop games loading.
    2) You need this. http://www.flashfxp.com/download.php
    3) Not sure, what prog did you use to copy it onto the HDD with?
    4) C64, spectrum, Amiga, PSX, pretty much everything, check out www.xbox-emulation.co.uk
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,382
    Thanks buddy
    I never copied anything onto the HD it came ready loaded
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,480
    +2,382
    installed that flashxp but still can not "see" my xbox
  5. rahulkohli
    rahulkohli
    www.xbox-scene.com has loads of tutorials on flashfxp and networking etc. it has everything about xbox u could ever want to know
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Best tutorial i've found for networking your xbox is here :)
    Well worth a read...
    K.
  7. WILD9
    WILD9
    Mar 12, 2003
    157
    Cheltenham
    +6
    XBMC struggles with DVD files at the moment, for it to play properly the VOB files need to be in a DVD image either a .IMG file or a .ISO file and even then it will only play the main movie it doesnt do menu navigation, as of know this is just about the only limitation of XBMC. to gather together the .vob files into an ISO file you need to use a tool like IMGTool
