Quantcast
What can an apple tv play and how
dUnKle
My xtreamer has given up the ghost so fancy an apple tv
What files can it play and can it play from a usb drive or a usb hard drive ?
Will it do .mkv and various high def files
Matt_C
VIDEO FORMATS
H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
MPEG-4 video up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
AUDIO FORMATS
HE-AAC (V1), AAC (16 to 320 Kbps), protected AAC (from iTunes Store), MP3 (16 to 320 Kbps), MP3 VBR, Audible (formats 2, 3, and 4), Apple Lossless, AIFF, and WAV; Dolby Digital 5.1 surround sound pass-through
In order to play .mkv and other file extensions, or other video codecs such as xvid/divx, you'll need to jailbreak it and install either Plex or XBMC. Likewise, you can only play from a USB flash or hard drive if you jailbreak. As standard it only streams from either online content (iTunes Store, Netflix [coming soon]) or from a computer on your network running iTunes.
Matt_C
I've not done it on the ATV2 - there are a few threads on here about it you can read up on - but when I did it on my ATV1 it was as simple as plugging a USB stick in and turning on the power!
Some people have had no probs with the ATV2, but some have had nightmares. Deffo do a full read up before going any further!
dwhite
There's also no way to directly attach a hard disk via USB to a atv2. Whether its jailbroken or not. It's network storage only.
dwhite
Nope, at least not unless its changed recently. The micro USB is only a slave port so can't handle hard disks, its basically there for updates.
