What Camcorder with A/V input
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by sas, May 16, 2002.
  1. sas
    sas
    Looking for a digital camcorder with a composite video input in the UK.
    I really don't care much for the other specs so a slightly older model will do nicely, and as cheap as possible.
    Can you guys give me some model numbers, I might even get one second hand so some old model numbers would be good
    Stuart
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Sony digital 8 models have DV and Analogue inputs on some models as standard, or if you use one of our Digi8 Widgets this will enable the DV and Analogue inputs on most of the rest of them.
    The new Canon Mini DV range has some models with Video inputs as standard also. Check out www.canon.co.uk for more information.
    Hope this is a good start for you !!
    Mark Theobald
    www.datavision.co.uk
  3. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    :smashin:
    Thanks Mark, been browsing for a couple of hours now and looks like one of the Canon models will fit the bill just nicely.
    GiZZeRR
