what cables
Discussion in 'Cables & Switches' started by ragonian, Jul 17, 2005.
  1. ragonian
    ragonian
    hi everyone,
    patiently waiting for my sagem hd45 to arrive after weeks of deliberation. now one thing left to think about - cables. I'm a novice at this stuff so need some help!!!! basically i will have the sagem, an xbox & sony dav-sc8 dvd/surround sound system - what cables will I need to run everything to its best potential and wheres the best place to get them?
    thanks in advance!
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    Although your TV is a DLP, the answer to a cabling question is pretty much the same irrespective of the type of TV. So you may get a more comprehensive answer in the cabling forum; I can move this if you like. Your choice.
  3. ragonian
    ragonian
    sounds goo to me - wasnt sure if there would be anycable specific to the sagem
  4. LV426
    LV426
    Jul 14, 2000
    12,789
    +4,975
    Moving to cables/cabling as requested.
  5. loadsofleads
    loadsofleads
    Hi, do you have a Sky STB, and is you Xbox modified for HD ?
  6. ragonian
    ragonian
    no sky, but getting the xbox modified soon
  7. loadsofleads
    loadsofleads
    If your getting you xbox modded that will require the component connections, but for now RGB scart is fine.
    Xbox Video - Sagem = RGB Scart
    Xbox Audio - DAV-SC8 = Optical
    DAV SC8 - Sagem = Component
    The cable that came with the Xbox was probably a composite connection, bin it and get a RGB scart cable, making sure it also has a optical output. I think Ixos make one but I don't think it has a optical output. With the component and optical I would probably opt for Supra, but I'm probably being biased :smashin:
  8. loadsofleads
    loadsofleads
    With a screen like that, you really should consider getting Sky HD when it comes out :thumbsup:
