What cables do you use to connect your AV setup?
jian
I just replaced a Lektropacks SVHS cable to the IXOS equivalent and was amazed by the difference, it was well worth the £25 I paid for it.
I now need another cable for my Toshiba SD9000 and was wondering whether there was an even better cable out there (SVHS).
I also need a pair of analogue audio interconnects, any suggestions?
J
juboy
After literally years of buying and swapping out various cables, the best solution interms of cost vs. perceived benefits are as follows:
Coaxial digital cable - Ecosse The Producer (oddly, a relatively cheap cable).
VCR/SKY analogue interconnects - Ecosse The Composer (again, comparatively cheap)
RGB SCART lead - Supra AV6
I have only ever used one type of component cable, the Supra AV3, but they work excellently as far as I can see.
If you're after cheap-ish but high performing stereo interconnects (and I can't really see the point of spending TOO much for hooking up the average VCR) then The Composer is a £29 pound, decent solution.
bh
QED and Ixos are two good mid-range brands of interconnects.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
