What cables do I need to buy
Discussion in 'Plasma TVs' started by kriswood5, Oct 29, 2004.
  1. kriswood5
    kriswood5
    Hi all
    I wonder if anyone can clarify how I should wire all this stuff up. I am new to all this so apologise in advance. I was initially going to buy an all in one system but decided to go for separates but now am a bit lost on how I should connect everything.
    I have a Pana Viera, Pioneer DV575 DVD, Pioneer VSXC502 Receiver, Sky+ and MS Genie speakers. Connecting speaker cables I am ok with :) but do I need to connect anything for the 5.1 surround sound?
    What I am not sure about is what connects to what and what cables/methods should I use. I am assuming that scart is the right route??? I have also read about Optical, is this better than scart?
    My plan is:
    Viera via scart to AV Receiver
    DVD via scart to AV Receiver
    Sky+ via scart to AV receiver
    Do i need to do anything for the 5.1 surround sound other than connect the speaker cables?
    Any advice is much appreciated.
    Thanks, Kris
  2. kriswood5
    kriswood5
    Hi Guys
    Being a complete novice, I could do with some help if possible. To assist matters with my question, I can confirm that I have teh following products with the listed terminals:
    Pana Viera Plasma Terminals:
    Composite Video Inputs AV3: RCA phono type x 1 (front)
    S-Video Input AV3: S terminal x 1 (front)
    Audio Input (for Video) AV3: RCA phono type connectors (L,R) (1 set, front)
    PC output Mini D-sub 15-pin x 1 (front)
    Audio Input (for PC) Co-use with AV3 Audio Input
    Component Video Input AV4C: RCA phono type x 3 (Y, PB (CB), PR (CR)) (rear)
    Audio Input (for Component Video) Co-use with AV4 21-Pin In
    21-Pin Input/Output
    AV1: AV In, TV out, RGB In (rear) /
    AV2: AV In/Out, S-Video In, Q-Link (rear) /
    AV4: AV In/Out, S-Video/RGB In, Q-Link (rear)
    DVD Player – Pioneer DV575 Terminals:
    Euro-SCART 1
    RGB-Y/C Video Output (on Euro-Scart)
    Component (Y, Pb, Pr) 1
    S-Video Output 1
    Video Output 1
    5.1-Channel Audio Output 1
    Audio Output 1
    Coaxial Digital Output 1
    Optical Digital Output 1
    AV Receiver – Pioneer VSX C502 Terminals:
    Multi-Channel Input 5.1 ch (LR via SCART)
    Digital Audio Input 4 (assign)
    Digital Coaxial input 1 (selective)
    Digital Optical input 3 (includes front 1)
    RCA Audio/Video Inputs 1 A / 1 AV (includes front 1)
    Pre-amp Output Yes (SW)
    A/V Input on Front Yes
    SR (System Remote) Terminal Yes (In/Out)
    SR+ Yes (for PDP connection)
    Speaker A/B A only
    Euro-SCART 4 (RGB: 3/1, Composite: 4/2)
    Speaker Terminals Clip
    Sky+
    Scarts?
    Given all this stuff, can anyone advise how I shoudl connect my system together?
    Your help is greatly appreciated as I am currently a little in the dark!!
    Kris
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Many possible combinations of course, but I suggest:
    Video
    Component from DVD to TV
    Scart from Sky+ to RGB Scart on TV
    Audio
    Optical lead from Sky + to AV receiver
    Coax digital from DVD to AV receiver
    So that's 4 sets of leads you'll need. Check the cables section for advice on which ones :)
  4. kriswood5
    kriswood5
    Thanks for the response, your help is very much appreciated.
  5. kriswood5
    kriswood5
    Sorry but one more question, to connect up my MS Genie surround sound system, do i need to do anything more then just wire in the sub woofer via a sub cable to the AV receiver and obviously connect the satellite speaker cables up?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    You got it mate Sub pre-out to Sub sinlge RCA lead and sateelite connect to AMP (I am assuming here check your manual)
  7. kriswood5
    kriswood5
    Thanks. I wasnt sure if I had to also connect the audio outputs from DVD into the AV using audio cables as well as the sub out etc but this is not the case so thanks.
