What cable?
Discussion in 'Desktop & Laptop Computers Forum' started by kilboypowerhead, Apr 14, 2005.
  1. kilboypowerhead
    kilboypowerhead
    I want to connect my PC to my Panasonic AE700 projector. My gfx card has an s-video output and a DVI output spare. Which one would give me the best picture?
    My options are
    1) s-video on PC to s-video on Projector.
    2) DVI on PC to HDMI on Projector.
    3) DVI with VGA adaptor on PC to VGA on Projector.
    I want to use it mainly for watching films but occasionally playing games too. I'd appreciate any comments on my options.
    Also anyone know where I can get a bog standard (ie sub £50) 8m DVI to HDMI cable? If that's the way to go.
    Michael
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Option 2, DVI-D, no question. :)
    8m is getting on the long side for standard quality digital cables, I've not seen any DVI->HDMI of that length under £50. I'd suggest you contact Joe at The Media Factory and see what he has to offer.
  3. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    I'm going through the same thing at the moment with my ae700 ! :)
    right now i'm banging my head against a wall trying to use a dvi-vga adaptor (radeon 9600) to give me an rgb feed that i can send to the pj's scart input - can't get powerstrip to let me tweak the dvi connector's setting to be widescreen etc. i too would have gone dvi-hdmi (still have the widescreen sizing issues??) but the cable cost is prohibative.
    Duncan
  4. JonMace
    JonMace
    Nov 20, 2002
    2,536
    83
    Kent
    +207
    Option 2 as said
  5. sunlink
    sunlink
    Currently using option 2 and getting 720p or 1060i.
    Steve :hiya:
  6. kilboypowerhead
    kilboypowerhead
    Thanks for all the replies. I strongly suspected option 2 was going to be the one. I've emailed Joe as suggested - hopefully he can do me a cheapish cable. I guess that option leaves me ready for High Definition DVDs in the future too.
    Just got to wait for the builders to finish converting the garage now.
    Michael
  7. kilboypowerhead
    kilboypowerhead
  8. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
    Its said that digital outputs don't like travelling that far without some sort of signal voltage boosting. The further you go the greater the cable resistance and the voltage drops. I wouldn't get it any longer than you needed. You maybe lucky. That is certainly cheap. From a known supplier, but 10m.
    http://www.lindy.com/uk/productfolder/04/41106/index.php
  9. kilboypowerhead
    kilboypowerhead
    That's another option. I've emailed the ebay seller too - I might take a chance if he can do 10m cable for a bit cheaper. Nothing ventured....
  10. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    was thinking the same thing ... let me know how you get on with that seller :) !
