what cable
Discussion in 'Cables & Switches' started by paulefox, Nov 10, 2004.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    should I use between a denon 3805 amp and a pioneer 757ai DVD player
  2. WarLock
    WarLock
    between my 3805 and my pio 868 i use a digital optic cable.
    it´s the best for home cinema
    for dvd audio music my manual says that i should connect all rca plugs from the 5.1 audio out into the receiver, but i havent done that yet.
  3. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    sorry I mean't to say what make and model of digital interconnect should I use
  4. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Get one from Mark Grant mate :D Use a SPIDF rather than a Toslink :smashin:
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Really why is that ?
  6. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    I heard the coax was best
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    if you ca hear the difference i will eat my hat...... I do prefer Coax for DVD but only because so much other stuff uses optical.... Sky+/Xbox/PS2/etc etc etc
  8. bobbypunk
    bobbypunk
    There is a difference with optical and coax. Whether it's audible depends on too many things. I agree with using Mark Grant's cable most people swear by them.
    But if you want a branded cable the for you're equipment i'd reccomend the QED Signature75. (Optical is best for long runs though)
