What cable will I need to connect Quintro scart switcher to Panasonic Plasma
Maximumbaz
Established Member
I want to connect my existing RGB equipment into a Quintro automatic scart switcher and need to know what type of cable is needed to connect it to a Panasonic TH-42PWD6.
I intend to use the Component / RGB inputs on the Plasma and switch to RGB. The RGB is pretty obvious but will I need to connect anything to the VD and HD sockets.
Looking at the Keene website makes things even more confusing because there are Scart to 3,4 & 5 BNC with RGB RGsB Hsync Vsync TTLSync etc etc .
deman77
the best option would probably be to use an RGB to VGA convertor and stick it into HD15 on your plasma.
Which means you'll need a scart cable from quintro to convertor and VGA calble from convertor to plasma.
if you are on tight budget you can go for a passive convertor. this way it will be just one cable from scart to vga.
⭐Best TVs, Soundbars, Hi-Fi and Home Cinema of 2023
Back
