what cable to get??
Discussion in 'Cables & Switches' started by randompolyphony, Jan 5, 2012.
  1. randompolyphony
    randompolyphony
    May 12, 2009
    91
    2
    +15
    Hi all. I need some opinions on what is a sensible cable approach. I have a pair of monitor audio rx6 speakers connected to my pioneer lx83.
    Currently using some fairly thick gauge copper speaker wire i aquired from my dad before i had these speakers and amp.
    Now i have the option to bi-amp the speakers and was looking at the van damme cables. I like the blue over black as my impression was it was more hifi orientated. (please correct me if wrong)
    Now i had almost decided to go for 2.5mm blue when i saw sone pists saying 4mm was better.... So the questions are
    Van damme blue or black?
    2mm or 4mm ?
    Is it worth bi-amping?
    Are two 4mm blue cables to each speaker going to look overkill?
    WAF is an issue but should be ok if a difference is noticeable over current setup!
    Thanks for the help
  2. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,651
    2
    The Fylde Coast
    +13,131
  3. randompolyphony
    randompolyphony
    May 12, 2009
    91
    2
    +15
    Many thanks mr incredible! Each speaker is about 3m from amp so 6m of that cable is very good vfm. Would i notice difference between the 2.5 and 4mm versions sonically do you think?
  4. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,651
    2
    The Fylde Coast
    +13,131
    Hard to say, but 2.5mm should be fine and no different to the 4mm for 99% of domestic installs!
