What cable for PC to LCD?
r1chehUK
Hey all,
My Hyundai Q261 is getting delivered tomorow and I would like to connect it to my PC to use it as a monitor. I have a Radeon 9800Pro which has a normal VGA connection and DVI as well.
What would be the best way to connect it, and what cable/s do I need to do this?
Thankyou :)
Redeye UK
r1chehUK said:
Hey all,
Thankyou :)
Looks like the TV has VGA and DVI as well. In theory DVI should give slightly better results but it's something you need to test for yourself. Also you might want to use the DVI to connect a DVI/HDMI output device in the future.
