What cable do I need?
Discussion in 'AV Receivers & Amplifiers' started by avok, Aug 12, 2004.
  1. avok
    avok
    Hello,
    I hope someone here will help me because the question is too much for the most shop salesmen :)
    I have to make a connection between Creative SB Live 5.1 -> Home theatre system LG LH D 6540D
    The signal is at the digital out of the SB. It has a adapter to RCA female
    My receiver has COAXIAL DIGITAL IN input.
    The distance is 15 meters. What cable do I need? A coaxial 75Ohm, 50 Ohm?
    Or some other type of cable?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    You need a 75 ohm digital coaxial cable with RCA connections.
  3. avok
    avok
    Thank you! But I cannot find cable with this length here. Can I make one from ordinary 75-Ohm coaxial cable (for cable TV) and two male RCA jacks?
  4. cityonfire
    cityonfire
    go to your local dealer and ask for a 75 ohm coaxial cable with RCA connections 15m in length. If they even deal with half decent cable suppliers they should be able to get one custom made for you. Do not use cheap stuff as the distance the signal is traveling will end up giving you a bad sound. I suggest asking for a QED P75 cable as QED do custom lengths to order
  5. avok
    avok
    Thank you! I got a custom cable made for me and it works perfectly!
