what budget camera can i get to at least see some detail of the moon pls ?
Discussion in 'Photography Forums' started by truewraith666, Jul 27, 2018.
  1. truewraith666
    truewraith666
    Apr 29, 2010
    38
    hi
    i was trying to take some pics for my kids of the moon but i cant seam to get any detail of the moon at all and its even worse with my smartphone. i just wondered if there is a camera out there at not to high a price that can take these type of pics of the moon etc please?
    my current cam is old and not so good fujifilm jv300?
    unless my settings are wrong!
    thanks
  2. John7
    John7
    Aug 6, 2004
    2,848
    +998
  3. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    Cheapest option is probably one of those superzoom bridge cameras like the Nikon p900 with an 83x zoom. However, you’ll probably need a tripod as camera shake will be very pronounced at that equivalent focal length.
  4. DGN
    DGN
    May 10, 2013
    50
    11
    Lens and focal length will be more important than camera. A tripod will be essential as previously stated.
  5. shotokan101
    shotokan101
    Jun 16, 2009
    75,865
    33
    Glasgow
    +25,825
    Also stacking multiple exposures can give impressive results
  6. wysinawyg
    wysinawyg
    Feb 27, 2006
    890
    63
    +254
    It’s something like 1200mm equivalent to fill the frame with the moon. At 400mm i find I’m starting to get a decent bit of detail when zooming.
    So bare minimum for something new would be £200 ish for a Canon SX620 and a cheap tripod.
    Another £70-80 quid would get you one of the cheap bridge cameras with a 40x zoom that would be a better bet though.
  7. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    Can you just stack multiple shots of the same exposure so you're just enhancing detail rather than increasing the DR, or would this not work?
  8. shotokan101
    shotokan101
    Jun 16, 2009
    75,865
    33
    Glasgow
    +25,825
    Well they need to be different shots :devil: but yes that's basically the process though I don't see why you couldn't also try adding some +/- shots to also boost the DR.....
    Photographing the Moon | Northrup.Photo
  9. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    Did you miss the bit where I wrote multiple images? ;))
    You could, but then the moon has never pushed the boundaries of DR for me :smashin:
  10. shotokan101
    shotokan101
    Jun 16, 2009
    75,865
    33
    Glasgow
    +25,825
    And where was that then ? :devil:
  11. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    Shots/images, same thing :p
  12. shotokan101
    shotokan101
    Jun 16, 2009
    75,865
    33
    Glasgow
    +25,825
    I say Potato you say Tomato :p
