What budget cables for the B&W 603
Discussion in 'Cables & Switches' started by ninjai, Dec 15, 2004.
  1. ninjai
    ninjai
    What do you use or recommend for the 603 and LCR60? I know good cables are expensive. But what budget cables are there that are considered as really not bad? I heard some recommend Analysis Plus. Thanx!
  2. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Do a quick search in the Cable forum for Cat5e cable - braided from network cable and supposedly very capable. It works out much better value than "budget" cable and outperforms many more expensive cable.
