what brand of speaker cable?
Discussion in 'Cables & Switches' started by gino555, May 30, 2005.
  1. gino555
    gino555
    Mar 27, 2005
    411
    +7
    What is the best make of speaker cable? I was looking at QED SA but I have seen mixed reviews on here!! I dont want to use cat 5 as I just dont have the time, are the van damme cables any good? I want to spend upto £5/metre, is jumpers better that biwiring? as it will save me a bit on cabling
    thanks
    gino555
  2. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    Whoever replies to this is on a hiding to nothing!!!
  3. gino555
    gino555
    Mar 27, 2005
    411
    +7
    cheers mate!!!!!!!!!!!!!!!!!!!
  4. gino555
    gino555
    Mar 27, 2005
    411
    +7
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,538
    Near London.
    +208
    Mad smilies won't make anyone want to reply but I'm in a good mood so you're lucky.
    There's very little between cable brands once you're spending more than 50p/metre. The differences are in the geometry and having sufficient cross-sectional area - 2.5mm^2 is more than enough for hifi purposes. Jumpers are the same as biwiring so save the cash if you want.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    It's all very subjective and each make of cable seems to have as many devotees as detractors. SA is very popular and there are a number of recent threads here about Van Damme cable so a search should yield plenty of reading material for you.
  7. gino555
    gino555
    Mar 27, 2005
    411
    +7
    thanks for the advice I have read about the different cables and i am more confused than when I started!!!! but it seems clear now that bi wiring is a waste of my hard earned cash!
    gino
    Van damme or QED SA ?????????? still cant decide
  8. bobbypunk
    bobbypunk
    The one thing that does tally up from all the "discussions" about speaker cable that happen on here is that Silver anniversary is a damn good cable. To stop ANOTHER "discussion" starting I will presume that you can afford to buy it, and you want to buy a branded cable!
    I suggest getting a demo on it cause I personally feel it's all subjective, personally Van Den Hul cables suit my personal taste but SA is a good cable!
  9. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    QED SA for me is too expensive when Van Damme is equal if not better at around £3 per metre cheaper. Buy the Van Damme it is dirt cheap and test it and see what you think.
  10. loadsofleads
    loadsofleads
    Nobody seems to have mentioned the excellent Supra range, can't be beaten in my opinion, but I guess I would say that :D
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,243
    The Borders
    +2,941
    gino555
    You don't mention what loudspeaker or loudspeaker system you have, what size/type of binding posts are on the Stereo or AV Amp and what length of cable runs you require.
    Best regards
    Joe
