What bolts do i need to wall mount my 42pe50?
N
Not A Clue
Getting all my stuff ready for forthcoming wall mount project - it said in the manual that I need M6 bolts which has left me slightly confused due to the variety available...
Its a new house with the plasma being attached to a brick wall...
Is it the M6 roofing bolts I go for?
What length?
What size drill bit will I need ?
Given they are bolts do I still have to put in wall plugs - if so do these have to be slightly longer than the bolts?
Thanks for your help - going to B&Q in about 2hrs so any responses would be appreciated :)
Plasplugs do a high tensile screw with rawplug attached for about £5 for 10 - 8mm masonry drill bit - from memory i think they are 80mm long. I have used these to put up an RS100 mount with a 42kg samsung perched on it. The more screws you use the less stress on each...
thanks for the response - can anyone else help with the list of questions :lease:
If you have a look in the PV500 and general plasma FAQ sticky HERE.
I think I used M8 rawl (or anchor) bolts 85mm long and a 14mm masonry is required. You need to hold it on min 6 bolts as a guide.
They have the anchors built in so you just drill the righ size hole.
Yu can also use M6 with a 12mm masonry bit, I would probably use 8 of them.I would use 60-85mm long.
B & Q call them anchor bolts, heavy duty ones, there is a pic on one of the links.
Not A Clue said:
Is it the M6 roofing bolts I go for? M6 or M8 ANCHOR OR RAWL BOLTS
What length? 65-80mm
What size drill bit will I need ? 12mm or 14mm Masonry
Given they are bolts do I still have to put in wall plugs - if so do these have to be slightly longer than the bolts? No, they have the anchor built in
Not a Clue ???? :smashin:
cheers mal - being dumb, didn't think the pv500 had the same wall bracket so didn't check :oops:
quick question for you given i have seen your wall mount project...
i am planning on putting a plug socket in the middle of the wall bracket to which I'll connect the panasonics power lead...(the reason being, if my pe50 goes wrong i can return everything without having to rip out the chased cables - all component cables will be chased in)
do you think theres enough room behind the plasma on the standard wall bracket to do this (i had a quick look yesterday at the size of the plug vs the depth of the wall bracket and i think i can manage to squeeze a plug in :confused:
cheers pal,
nac
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
