What board for bathroom
Discussion in 'General Chat' started by has2mow, Dec 1, 2017.
Tags:
  1. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    Currently gutting the main bathroom, I have pinched 500 mm from the bedroom next door and built a stud wall, went to purchase some waterproof plasterboard and they only have sheets of 1200 x 800.
    Should I go for normal board and skim and tank with something ?
  2. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    this new wall will be against the bath and shower.
  3. ufo550
    ufo550
    Sep 20, 2014
    1,609
    113
    Oxfordshire
    +925
  4. George a L
    George a L
    Jan 9, 2005
    483
    2
    43
    Scotland
    +138
    Defo moisture board you are after around £15 a sheet from any builders yard.
  5. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    The boards they had were £12 a sheet plus the vat.
  6. George a L
    George a L
    Jan 9, 2005
    483
    2
    43
    Scotland
    +138
  7. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    Many thanks will get some in the morning.
    Should I plaster as normal or just tile direct to board?
  8. Wahreo
    Wahreo
    Oct 11, 2012
    15,592
    +13,050
    If it’s in a wet area then MR plasterboards are pointless. They are not designed to go in a shower area.
    I would use either:-
    Tile backer board.
    Plasterboard and then tank.
    Never skim plasterboard if you’re tiling it. It does more harm than good.
  9. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    Thanks mr bathroom :thumbsup:
    So standard plasterboard and some tanking anything you would rate to use?
  10. Wahreo
    Wahreo
    Oct 11, 2012
    15,592
    +13,050
    Mapei Aquadefense Kit. £50
    Toolstation
    • Like Like x 1
    • Thanks Thanks x 1
    • List
  11. has2mow
    has2mow
    May 19, 2008
    1,060
    113
    +584
    A very busy day with the sparks in, looks like a late night popping ceilings.
    Ist fix in with bathroom and new fuse box fitted, and all backplates marked out.
    I have started to reboard the ceiling in bathroom and have just thought should I add insulation like rock wool or something from the bathroom to bedroom wall ( stud wall ), it will be the bath and shower wall ?
    Thoughts please
