What barco are these CRTs from?
Discussion in 'Projectors, Screens & Video Processors' started by perhaps, Apr 25, 2005.
  1. perhaps
    perhaps
    Hi, im new to the forum and need some help identifying some CRTs I have found. Does someone know the application or know someone who might be able to tell me? Part Numbers follow:
    R7631832K - Red
    R7631836K - Blue
    R7631835K - Green
    All I know is that they are for a Barco, im looking for the model barco they fit.
    Thanks for your help.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    These are 9" CRT's from a simulator.
    The mounts are very specific as they are from the split unit.
    The "k" shows they are a spare part rather than the original tubes.
    These are not normal tubes that would go into any old 1209.
  3. perhaps
    perhaps
    Thanks for the information, I had searched the net for a few hours looking for the application of the crts to no avail. Would you mind telling me where you found the information? It may be of use to myself and others on the forum.
    I'm assuming because they use a special mount, and don't fit into a conventional Barco 12xx, they are not a likely candidate for a home theater install. You saying the original application was a simulator makes sense as the seller stated they were military surplus when he bought them. I guess I know why he never found a use for them.
    Again, thanks for your help.
    Edit:
    I've just been told a bunch of these crts are on govliquidation.com so if anyone does have a use for them, now might be a good time to get them.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm a barco dealer I have worked with barco's for the last 20 years.
    I just know these things
