Blu tak leaves a messy residual in the long term. double sided acrylic tape leaves no trace or smell and is strong. Strong enough to attach a car number plate and lights on the motorway.Blu tac; blu tac & blu tac. - nothing worse than seeing a piece peeking out from underneath a speaker tho!
@password1 - interested in the washing machine pad idea. Looks like they come in all shapes and sizes! Any pointers to which one's you've found work?Squash balls cut in half and placed under my cd player.
Washing machine isolation pads under subwoofer feet. Does the same job as the expensive SVS isolation pads.
My advice is don't buy the cheapest you can find because I had to buy another pack. I tried to save money by buying the cheapest. The first pack were poor quality, edges a little rough, cheaply made and they were not completely flat. I have OCD and couldn't live with them not being the same shape and flatness. I bought another pack off ebay a long time ago I think they were £8 or £9.@password1 - interested in the washing machine pad idea. Looks like they come in all shapes and sizes! Any pointers to which one's you've found work?
The caveat to this is when you have a small room and or/fixed listening position.For virtually FREE - SPEAKER PLACEMENT.
I am stunned by how many people poorly place their speakers, typically too close to the wall behind the speakers. When the speakers are poorly place, it boosts the bass, and you would think that would be a good thing. But, when that bass boost happens, you get both MUDDY Bass and Midrange, and that generally sounds terrible.
Try pulling you speaker about 1 meter into the room to see if they sound better. If you like the results, then start working them back until you find the best compromise between Clarity and Bass.
You'll thank me in the long run.
Steve/Bluewizard
Steve/Bluewizard
Yup. Fairly much all of my many room issues have been ironed out by stopping faffing about with small fixes and succumbing to the call of Lyngdorf and Room Perfect.The caveat to this is when you have a small room and or/fixed listening position.
In my room, pushing the speakers into the corners then dealing with bass response/room modes with REW and filters was far better than having them awkwardly positioned.
Your wife should have some for the iron. If not supermarkets, Halfords (used in batteries, cooling fluid etc).where can you get demineralised water from?
Still alive and well, sometimes it kind of hard to tell, but I'm still alive and well.Nice to see you posting again Steve, was worried you might have succumbed to covid as you haven't posted for a long time. Welcome back.
The problem with the average size house in the UK is room sizes and most people dont have a dedicated perfectly shaped and treated listening room.
That's why I have a converted garage as a dedicated music room, with the added bonus of concrete floor.A few years ago we were looking around at new builds just because there seemed to be a lot of them going up around here were curious and I came to the conclusion that architects must learn exactly how to design houses to be as awkward as possible for a decent hifi and/or AV setup.
Typical open plan huge and oddly shaped kitchen/diner area but often a tiny lounge even in larger 4/5 bed houses.
I can understand that. I am semi lucky is that while I have a small house (2 bed chalet) its downstairs living area is quite big (6.5mx5.5m) and has a solid floor plenty of room for larger speaker to breathThat's why I have a converted garage as a dedicated music room, with the added bonus of concrete floor.
I don't know where this thread is going or whether it's a bit off topic. So........the syringe is good but put some olive oil drops in each ear for a couple of days and then use the syringe, it will help soften the wax and make it easier to flush out.Second the ear syringe which you can get done for free at your local surgery. If you have never had it done, DO IT. You will be slack jaw amazed just how much detail you have been missing out and just how fecking loud the outside world is under those layers of wax.
