What are the FULL HD (resolution wise) Plasma TV out there?
Discussion in 'Plasma TVs Forum' started by LCD Seeker, Aug 26, 2006.
  1. LCD Seeker
    LCD Seeker
    I looked at this site http://www.idealo.de and they only seem to list... 3 of them, 2 LG's and 1 Philips.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    erm do you mean 1080p panels?
    ATM there is only one a 50" Pioneer none of them are LG or philips (Hitachi make an ALIS glass that is 1024x1080p which philips buy and use)
  3. LCD Seeker
    LCD Seeker
    Yes there is lol:
    LG Electronics: 71PY10 and 50PC1R
    Philips: 42PF5620
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    cant find the 50PC1R On the LGE uk site 50PY2R and 50PC1D are both Resolution: WXGA (1,366x768) (according to LG) You are correct the 71PY10 is 1920x1080 (forgot about the big boy, is that in your budget?)
    And i cant see the philips you refer to on the Philips site either (none of the Philips 42 Plasma are 1920x1080 they are 1024x768 or 1024x1024 (ALIS) or 1024x1080 (ALIS)
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Found this in the support section, blatantly wrong...... as Philips would have the only 1366x768 plasma at 42" on the planet (and as they dont make PDP glass this is very odd) but still isnt 1920x1080!!!!!!!!
