Quantcast
What are the default cydia repo's?
Chox1988
could someone take a screenshot of their repo's in cydia, ive deleted the default ones by accident and cant find the exact addresses and its driving me mad :(
screenwotcher
dont want to be rude but this kind of thread helps no one,, you have asked a question and found the answer it would be good if you could tell us what you did.. this is a sharing forum in the future when someone else has a similar problem they will do a search and find your thread.
it might drive them mad just a thought
Chox1988
Hadnt considered that :), after a lot of trawling I went to cydia and then scrolled down to 'more package sources'.
Then the default ones you havent got installed are linked at the top to install, as you install them they are removed from that list.
