what are the best floorstanders to turn kef 2005.2 into 7.1?
Discussion in 'Home Cinema Speakers' started by cowtipper, Apr 5, 2005.
  1. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    As the titles says i have got a kef 2005.2 5.1 system and a denon 3803 i am looking to upgrade to a denon 3805 and add 2 floor standers to move to 7.1.
    They will be used for about 85% movies and 15% mp3 and dab radio
    I have considered the Kef q4's has anyone got any other suggestions?
    :lease:
  2. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    Anyone ?
  3. coldrobba
    coldrobba
    Mar 3, 2005
    185
    London
    +3
  4. Helicon
    Helicon
    Apr 4, 2005
    5,018
    +261
    If you're only going to change the front L&R, the Q4 will be the closest match. The Q5 will be much better than the Q4 but have a warmer sound than the 2005 satellites, and the single 2005 satellite will not keep up with both Q4 and Q5(although you could use two 2005's as a centre channel which will sound much better and definitely worth it if you really can't have a bigger centre). If you change all front three, go for the Q5 and Q9c(or pick up a 2nd hand pair of Q3's).
