What are OHM's?
Discussion in 'Home Cinema Speakers' started by hunkiemunkey, Apr 1, 2003.
  1. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    Hi there,
    I currently am awaiting the arrival of an Sony STR-DB780 receiver, and when looking at the tech specs, noticed that it has switchable 4/8 Ohm.
    What exactly are Ohm's? And is 4 or 8 better?
    The speakers I am using are Mission M73's, so what "Ohm" do you recommend I use?
    John :hiya: :clap:
  2. auldendunn
    auldendunn
    Nov 3, 2002
    76
    Fife
    Ohm is the unit of resistance/impedance.
    The impedance of a loudspeaker coil varies with frequency. So a nominal impedance is quoted ( fora certain frequency).
    The output stage of an amplifier also has a nominal impedance value. Best results are achieved, in theory, when these are the same value in ohms.
    Your Mission 73s should work on either 4 or 8 ohm setting as they are quoted 8 ohm optimal and 4 ohm minimum. You should get best results with the 8 ohm setting.
    I think this is right, but there are many here with much greater knowledge than mine and if I am wrong they'll be along in a minute. :D :rotfl:
