What are my options?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dustjunky, Oct 31, 2003.
  1. dustjunky
    dustjunky
    Oct 8, 2003
    69
    Manchester
    Hi there :)
    I am about to move into my new flat tomorrow and I want to get Sky installed. The previous tenant had Sky and he has left the dish and phone connector already in place soooo....
    Can I get a really good deal out of Sky becuase they dont have to supply another dish or am I better just following the standard installation route? Or is there something else I could try?
    Thanks in advance
    Ben
  2. Fernsehman
    Fernsehman
    Sky take no account of an existing dish because it could be distorted, misaligned and have a faulty LNB and cable, resulting in MORE work for the installer.
    You could buy a used Digibox then phone Sky and ask for a "Second Hand Contract" which you fill in and return to get a viewing card. Note that they'll tell you this contract will reach you in "4 - 5 days". Well, in my experience they mean "weeks" and, in view of the current postal strike you'll be lucky to see it before Christmas.
  3. dustjunky
    dustjunky
    Oct 8, 2003
    69
    Manchester
    So should I just phone up and ask for a standard installation plus mention I have a dish already? I assume they won't increase the price of installation for any reason :confused:
    Ben
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Make sure you check the internet and phone the internet number. The operators can see what number you are calling and will price you accordingly. I got my internet installation for £1 a couple of weeks back!
  5. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    As above, just apply on-line , ring the internet number or quote the £1 offer, reduce £38 subscription after first month if you prefer.
    Make sure the installer fits a new dish, so that you have a new LNB.
