What apps you using WHS for?
cmclean
What interesting things are people using their WHS for?
Anyone running Harmony Home Automation software or doing anything interesting with their game consoles connected to their WHS?
D20PAX
im in the process of specing my server hardware.
will be using it to supply blu-ray, hd-dvd and dvd movies to my media pc via the 'mymovies' app
one question i do have is, i play to run a 8TB raid 5 config but i already have 2 1tb drives that are full up.
will i be able to add these in full up or will i need to store the data and transfer it to the server after i have installed every thing
AMCross
"i play to run a 8TB raid 5 config "
you cannot run a raid system with whs
the os configs the drives as just a bunch of discs
And you can add more to the storage pool as you go along
AMCross
i am using the hd version as dvd decryptor is dead and buried although i still use it now and again
the hd version also allows hddvd and blu ray rips
AMCross
i have dome mostly hd dvd so not too sure about anydvd with blu rays
D20PAX
my movies has the option to rip blu-ray and hd-dvd ( requires anydvd for protected discs) from within the user interface
cmclean
But that's the beta version for WHS still right now isn't it?
I didn't think the full version was available yet?
PAH
IIRC, WHS will wipe any existing data from a drive when it's added to the pool, so you'll need to add some empty drives first and copy the stuff over before adding your currently full drives.
Chuck_Norris
i have a few things running on my whs.
sabnzbd - best program i have on there, really handy if you use newsgroups etc
orb - good fro streaming media to you anywhere
twonky media server- exactly what is says
myihome- as i use a popcorn hour
i'm looking into putting x10 on there at the min too, but info is limited.
wegotserved is a great site for info.
hth
Chuck:)
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
