What app to work out distance walked?
Discussion in 'iPhone Forum' started by p1tse, Jan 8, 2012.
Tags:
  1. p1tse
    p1tse
    Jul 24, 2008
    2,973
    68
    +83
    Took my little lad out on his balance bike and would be interested to find out distance covered by drawing on a map or something.
    Is there such an app if so which one would you recommend?
    A nice free one would be good ;)
  2. severe dainjah
    severe dainjah
    Jan 17, 2010
    1,169
    Perth
    +370
    can highly recommend Runkeeper - used it a lot last year to track times/distances when out walking/cycling
    easy to use, looks good and perhaps best of all it's free. word of warning though, it's a battery eater due its to constant use of gps
  3. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,696
    +1,585
    Edmondo seems to be the one my fitness freek colleagues use at work.
  4. p1tse
    p1tse
    Jul 24, 2008
    2,973
    68
    +83
    Thanks. Can either of them let me draw a route after to work out distance now?
  5. severe dainjah
    severe dainjah
    Jan 17, 2010
    1,169
    Perth
    +370
    Runkeeper doesn't let you plan a route, it just maps where you've been using gps and then draws a line on map and calculates the distance for you
  6. p1tse
    p1tse
    Jul 24, 2008
    2,973
    68
    +83
    Thanks. Want something which can plan route and distance. Although runkeeper might come in handy if I pick up running lol
  7. johnelf
    johnelf
    Nov 10, 2003
    705
    46
    Epsom
    +105
    Healthy is a free App from O2
    It works out distance walked speed rough calories burned and you can see the route on a map
    So all your requirements ?
    John
  8. lord-dudester
    lord-dudester
    Oct 27, 2006
    2,230
    Spalding Lincs
    +269
    endomondo is the one, I've tried nike gps and run keeper and endomondo tops them both
  9. bransoj
    bransoj
    Oct 29, 2009
    2,772
    103
    +474
    Used Runkeeper for ages now, both free and pro versions, and its never let me down for walking, running or cycling. Just change the type of activity prior to setting it going and away you go. Loads of stats whilst its running including overlaying your route on a map and then once done you have the choice of viewing it on the phone still with the same info available or more stuff available via the Runkeeper website on your computer. I tried Endomondo but wasnt as keen on it.
    Runkeeper also lets you edit a route afterwards to correct any mistakes or add bits if need be.]#
    The only thing i know off that lets you do a route on a map afterwards to work out distance etc isnt an app but a website called gmap pedometer :-
    http://www.gmap-pedometer.com/
  10. PeterH988
    PeterH988
    Nov 5, 2008
    1,244
    63
    +206
    Do any off these apps allow you overlay your route onto a satellite map?
    I've used run keeper, but you only see your route transposed over the road map, so my off road routes just show up as a squiggly line on a grey background.
  11. bransoj
    bransoj
    Oct 29, 2009
    2,772
    103
    +474
    With Runkeeper it also uploads it to their website where it overlays onto Google Maps so you get all the options you would normally get from looking at Google Maps.
    In terms of the app for me it loads the standard Google Maps view so anything off road shows up over green areas for fields etc but not a grey background. Normally it shows a grey background if it has no data connection to download the maps as its going. I had this when i used it to track a walk in France once and had my data connection turned off to prevent running up a big bill.
