What Amp should I get?
Discussion in 'AV Receivers & Amplifiers' started by Kryton3000, Apr 9, 2005.
  1. Kryton3000
    Kryton3000
    I want to use my amp as the main hub of my home cinema system and connect it to a Panasonic pw7 via either RGB Scart or Component.
    The equipment I want to connect to my Amp are :
    1 x Sky+ box (RGB Scart output + optical)
    1 x DVD player (RGB Scart output + Component output + optical)
    1 x Other satellite (Composite scart output)
    1 x Gaming console (Composite scart output)
    1 x video (Composite scart output)
    I could probably leave the video disconnected if I cant find an amp with the correct number of connections (its hardly ever used).
    Could someone recommend me a set up that would do the job for me? I see a number of separates systems out their that do not have SCART inputs but have S-Video, Component and Composite.
    What would I need to convert the above sources (I assume I would only need a JS RGB Scart to Component for the Sky+ box but the rest would be a straight forward scart 3 phono (video/Left/Right) converter). Also please recommend some speakers which may complement the system.
  2. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    Any indiaction of prices for the amp and speakers??
  3. Kryton3000
    Kryton3000
    I was hoping to pay up to £700 including speakers, hopefully lower though.
  4. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    The Yamaha 750 can be got for around £300 from Germany...this is now being replaced with the 757 so a bargain may be found. This has 7 composite inputs, 7 s-video inputs and 2 component inputs. All can be upconverted to component. I would advise
    DVD - component
    Sky - JS RGB scart to component
    All the rest composite......this may look pretty awful on the panel so if you have S-VID go for this instead
    For speakers I would recomend taking a look at the Canton powerbuy in the speaker section. I am sure you can get a very nice set with the remaining £400.
  5. Kryton3000
    Kryton3000
    Does the Yamaha 750 have 2 optical inputs?
  6. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    It actually has 3 optical inputs and 2 digital coax inputs. It is well received on these forums and is a great performer on music and films for the price.
