What amp/receiver for about £1000?
Discussion in 'AV Receivers & Amplifiers' started by Glenn Keen, Aug 29, 2001.
  1. Glenn Keen
    Glenn Keen
    I'm looking to buy a new amp/receiver for use with my DVD player.
    I've got a budget of about £1000.
    The Denon amps sound good value with lots of support for most of the audio formats. But is there something that is a 'must have', such as Dolby ProLogic II? And is have a THX certified amp worth it?
    Any suggestions for all you experts out there would be greatly appreciated.
    Thanks,<br />Glenn Keen.
  2. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    What is a 'must have' for one person isnt a must have for all.
    <br />Take Pro-logicII - if you dont listen to any(or much) pro-logic encoded stuff(just 5.1 & stereo) then its a wast.
    You've got feature rich recievers like the denon 3802 or simpler stuff like the rotel rsx972 which might sound better for music.
    As always - decide what you need ( number/type of inputs/outputs wattage etc) and have a listen to a group of competing products.
