What amp for under £300???
Discussion in 'AV Receivers & Amplifiers' started by damienb, May 24, 2001.
  1. damienb
    damienb
    Apr 5, 2001
    28
    UK
    Hi Guys,
    was just wondering what amp you would recommend for under £300, I know it is a small budget but I have to stay low due to having to buy the flat to put my new system in! Have read the review of the new Kenwood in this months HCC mag, anyone got one? Is it as good as they say for £230? Have you got a better suggestion?
    Oh, I have already bought the Philips 28PW6305 widescreen that will be the centre of the system, and a Sony DVP525S which I will be using to decode DTS and DD. Front surrounds are going to be my floor standing Eltax's, which have a loads/too much base, so won't be buying a sub, and will probably be buying the Richer Sounds 3 Eltax speaker package for £100 for centre and rears.
    All ideas welcome, thanks in advance,
    Damien :confused:
  2. damienb
    damienb
    Apr 5, 2001
    28
    UK
    Also, have just been to Richer Sounds and spotted they are selling the Kenwood KRFV5050 (Silver) for £179.95! Any views on this??
    Damien
  3. jonny
    jonny
    Aug 14, 2000
    285
    Hertfordshire
    +3
    I have been in the same situation for months and i decided on the denon 1801 i also looked at the Yamaha A5 Denon 1601 and a few of the sonys but i know these are crap for music. If you arnt going to use the amp for music then i suggest you look at the www.upgradeheaven.co.uk/clearance.htm website, they have a sony 840 amp for £270 which is £130 off the normal price. ive dealt with these guys before and they are excellent. Or alternativly www.sdb-electronics.com have a few good deals like the denon 1801 which was only £250, and ive seen it advertised for alot more. I dont really know about the kenwoods because ive had problems with budget kit before so i stayed away from it this time. I think you shuld look at the Yamaha A5 Denon 1601 or 1801 and pioneer also do the ??609 which is also meant to be a good preformer.
    Hope this all makes some sense and helps, Jon.
    [ 24-05-2001: Message edited by: jonny ]
  4. knobitt
    knobitt
    Spotted the Kenwood KRFV5050 over at Empire Direct for £173(Black or Silver) ;)
    Shop around you'll find a Yamaha A5 for £250
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the A5 is good and you can get them cheap, especially because they have been replaced. But my honest advice, i have an A5, is to save your money! another £300 will get you looking at a denon 3801....which is an entirely different league!
  6. Wozbit
    Wozbit
    Have you had a look at the sony STRDB-930 as this a better unit then the 840 you have looked at, also if you go to richer sound's get a copy of what hifi and look at the add as the price will be lower then in other mag's and make sure you take it with you to them or you will pay more.
    hope this help's.
  7. stefinch
    stefinch
    I have the Yamaha A595a, the build quality is excellent, had it a few years now and never had a problem with it. The sony 930 is a great buy from richer but thats if they have them in stock (probably not). Try hyper-fi London (advert in What hi-fi mag) these also do some great prices on all the above.
  8. chris thomas
    chris thomas
    go for the sherwood r925 the best budget amp on the market. :D
    it,s a bit more expensive than the yammy 595 but takes it clean out.
    [ 27-05-2001: Message edited by: chrisyt ]
  9. Guest
    Whilst not wishing to appear rude, i would not heed the above post's advice.
  10. chris thomas
    chris thomas
  11. Guest
    Again not wishing for "tittle-tattle" involvement here, i think (in fact i would go so far as to say i know) that you 99% of long term/experienced H.C. enthusiast's would chose Yamaha A.V amps/recievers over Sherwood on reputation alone without. Yamaha has a long standing affection from H.C lovers, for many of us it was our introduction to the "addiction".
    Yamaha : Solid Build, Solid Performance, Utterly Reliable (I've owned 3 but now use Denon).
    Sherwood, particually the 925 (which is VERY old now) from my obsverations : Average Build, Average Performance but weedy output stage, Not Terribly Reliable - this model tended to blow up - literally!!!
    Regards (without malice)
    SteveEX
    P.S. I have never owned a Sherwood (nor, most likely, will i) but have spoken/corresponded with many who have.
  12. Dodgey
    Dodgey
    I had a sherwood, had it changed 3 times over 12 months because of various faults, some intermittent. Then got it upgraded to Yam 595a (A5 pretty much). Verdict (and this IS considering that the Sherwood was ASTOUNDING VALUE at the time of purchase, but not any more...)
    Sherwood blows in every way. Poor sound & build quality.
    Yamaha sounds 100 % better. The surround feels "natural" and enveloping exactly like the Sherwood does not.
    Cya :)
  13. Guest
    Case closed i believe
  14. chris thomas
    chris thomas
    no, i,ll be back to re open it later, but i,ve gotta shoot off for now! ;)
  15. dvdmods
    dvdmods
    Dont know if this is any help,but there is a Yamaha DSP3090 on ebay for £300 which has met its reserve price and is a very good amp.
    I know Richer sounds also do some great deals.
    Rob
  16. Greyhound
    Greyhound
    Aug 23, 2000
    64
    With regards to the Sherwood, its better to spend a little bit extra on something better. I have a Sherwood and I'm not totally happy with it when it comes to its output. :(
  17. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Yes, I agree with SteveEX, but I think that I would go as far as to say that Yamaha and Denon rule the Home Cinema roust as far as integrated amps go; you won't do much better than any model by these manufacturers (at their price points).
    Mark
  18. paiger
    paiger
    Who said Sony amps were rubbish at music. Not on your nelly matey. My 940 rocks and HC is awesome. Mind you, my speakers did cost more than my house.......
    S
  19. knobitt
    knobitt
    Slightly over £300 at Richer is the Yamaha A5 replacement, the brand spanking new DSPAX620 :)
  20. JulesH
    JulesH
    May 16, 2001
    91
    +3
  21. damienb
    damienb
    Apr 5, 2001
    28
    UK
    Thanks to all of you who have offered your advice and comments. I think it is looking like a test drive for the Yammy A5! Will let you know how I get on.
    Damien ;)
  22. damienb
    damienb
    Apr 5, 2001
    28
    UK
    Just remembered (several months on) that I never did say how I got on! Thought I would keep you all on the edge of your seats for a while. Ended up buying (drum roll please........)
    The Yammy DSPAX620! Got it from John Lewis price matched from can't remember were. They were still selling the A5 for £400, and got the new model for £290ish! Was and am very pleased, lovely amp, great range of options.
    Damien
  23. DiabloRex
    DiabloRex
    Good to know what model you ended up picking.
    But you call a year and a half several months? :) lol
  24. damienb
    damienb
    Apr 5, 2001
    28
    UK
    It was intended to carry a certain amount of irony! lol
    Was browsing the forum for something else, and this thread that I had started came up in the results, so thought I would read it again just for fun, then realised I hadn't finished it! Although I do think that I posted the fact that I had bought it in a seperate topic. Anyways, now it is out there for all to see.
    Cheers,
    Damien
  25. LBB
    LBB
    Nov 27, 2002
    114
    +8
    Either go for Yamaha DSPAX620 or Marantz 4200. Both going for £200 if you look in the back of What Hi-Fi at the Richer Sounds advert. Have a Yamaha DSPA-5 myself and can't fault it.
  26. Taz
    Taz
    LOL!:D go back and read the 3 posts above yours! LOL!
    Taz.:cool:
