What AMP do I buy
Discussion in 'AV Receivers & Amplifiers' started by LynE, Feb 20, 2002.
  1. LynE
    LynE
    I have a Toshiba 210e plugged into an overloaded Sony TV, SCARTS that is.
    Now I want (or is it my other half is letting me ???) some sort of Home Cinema AMP, and speakers.
    The only must is a remote control for the volume !!!
    What do I go for ???
    I have £300, it doesn't have to be the newest, been a Richer Sounds fan for years
    Any ideas out there .. URL's to follow ..... etc
  2. Guest
    Yamaha RX-V620
    £299 rICHER SOUNDS
    Fine Amp
    Fine price
    Tal
  3. Guest
    whoops
    You want speakers as well for £300
    good luck
  4. hoppy30
    hoppy30
    I'm in same boat a you. Would like decent amp and speakers too. Been looking at Sony HTK-475 for £370 from techtronics.com
    Seems to get good reviews and has dolby and dts decoders with speakers and subwoofer.
    Best I've found so far.............
    Still looking
    Dave
  5. Guest
    Get yourself down to your nearest debenhams or check their website. paramount pictures hcs5300 £299 or £284 if you sign up to one of their cards. Dolby digital,DTS and prologic, im very impressed with mine, now that I've replaced the standard speaker cable its even better.
  6. Guest
  7. Guest
    Sorry forgot to mention also check out the review on the what tv & video website.
  8. bob007
    bob007
    A bit more than your budget but here goes.
    KRF-V5050D Silver Dolby Digital/DTS AV Receiver
    5 x 100W power output, 6 channel input for DVD Audio, FM/AM tuner with RDS
    5 DSP Modes and Cinema EQ Modes
    Bass/treble Control, Preset Call, Sub preout, monitor out, headphone socket £166.97
    CRESTA C Cherry Centre Speaker
    120W max power handling (8 ohms)
    25mm (1") tweeter with twin 100mm (4") long throw bass/midrange drivers
    Bi-wirable
    Magnetically shielded £71.96
    2x
    CRESTA 1 Black Bookshelf Speakers
    Compact, 2-way bass reflex design
    70W max power output (8 ohms)
    25mm (1") silk dome HF unit
    100mm (4") long throw bass/midrange driver £71.96
    Total........£383.85........then save for a decent sub.
    You could choose Wharfedale diamond centre....... 2 pairs 8.1's
    £270=speakers and £167.96 amp .......£437.96
  9. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
  10. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    Location location location
    +94
    Without a doubt current "hot potato" is the marantz SR4200. if you`re a member of the DVD forums, you`ll be able to pick one up for £250 through the bargain forums there.
    Extra £70 would get you the 6.1 Marantz SR5200, which just got 5 stars in What hi-Fi this month.
    If you need something with speakers, then as suggested already in this thread, the yamaha HTiB40 is a good value pack for £400:)
    Hope this helps?
  11. LynE
    LynE
    Cheers guys.
    Will have a look for the Yamaha RX-V620 and HTiB40 over the weekend.
  12. triplebj
    triplebj
    I'll sell you my Kenwood 5050 for £110 ;-)
    BJ
  13. LynE
    LynE
    Ok, guys,
    Went to my local HiFi shop, Audio Excellence, to suss out the Yamaha mentioned above.
    Have a chose of the new RX-v420 for £300 or a ex demo RX-v620 for £300.
    Also the guy reckons the Marantz SR4200 is very good, with prologic II at £300 or the SR5200 for £400.
    OK any ideas or thoughts on which is best ??????
    Or any alternatives ?????
  14. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    You could get a brand new Yam AX620 for £300 by shopping around, off the net or instore from Richer Sounds is one such place.
    SR5200 has the quality and features which would probably make it the best choice (says the Yam AX620 owner miserabley), and the most expensive.
  15. Justin@UH
    [email protected]
    Feb 21, 2002
    2,194
    63
    +94
    Go for the marantz, but go to dvdforums, register (if you are not a member!) and get the Sr4200 for £250, or the SR5200 for £330!
    Another option worth considering is the Yamaha RXV420RDS, nice budget receiver for under £250.
    hope this helps!
