What am I doing wrong?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Jaime, Sep 10, 2004.
  1. Jaime
    Jaime
    Hi Guys,
    I'm new so i apologise profusely if this has been covered, and, I am a beginner so i may not understand all the tech talk.
    I have a Panasonic mini DV NVDS29B camcorder and am trying to record on to CDRW.
    I have just managed to do it using the trial version of Pinnacle movie studio 9, I didn't manage it on Ulead studio 5.
    I have firewire connectivity.
    My problem is this, the picture is appalling on the full 17 inch monitor and tv, however it is beuatiful on the small screens when editing, and the camcorder LCD screen with playback.
    What am i doing wrong? Is my camcorder no good, I thought DV was supposed to be "lossless" but my old VHSC is heaps better!
    I can't afford another camcorder and don't understand what's wrong.
    I would appreciate any help guys!
    Jaime
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Are you saying playback of the CDR is bad on monitor & TV ?
    If that's what you are saying , then yes it probably will be. DV is lossless but the MPEG encdoing you have to make VCD & SVCD is not. If that is the case instead of buying a new camcorder do yourself a favour & buy a DVD writer. They are cheap & with that you should be able to create DVDs that will as good as your DV footage for a minimal outlay.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Agree that you should get yourself a DVD writer. With prices starting from £50 or less they are not that expensive and are a massive improvement over VCD or even SVCD.
    In order of quality for output going from worst to best:
    VCD > VHS > SVCD > DVD > DV
    You could try SVCD as a stop gap, but be aware that SVCD will not play on the majority of DVD players.
    Mark.
  4. Jaime
    Jaime
    Thanks Guys,
    The CDR playback is really bad on both monitor and TV.
    Also, the playback on the full screen monitor is bad using the video editing software. (Pinnacle movie 9 trial)
    Windows movie maker is slightly better.
    So all I need to do is buy a DVD writer and that will correct the problem?
    Can you recommend one that accepts all the DVD formats?
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I doubt you'll need one that will do ALL formats.
    Pioneer's are generally well regarded, look at the latest of those. Think model number is probably 108.
  6. Jaime
    Jaime
    Thanks!
  7. ketank
    ketank
    Hi there it seems me and u have the same prob but like advised i'm getting a dvd writer.... I notised u use Pinnacle 9 trail version..... Does it Freeze ur machine??? cos it did to me, BIG TIME!!! and therefor uninstalled it?
  8. Jaime
    Jaime
    Yes,
    Pinnacle movie studio keeps crashing, freqentley!!
