What aerial does everyone use?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by f0rmula, Mar 14, 2005.
  1. f0rmula
    f0rmula
  2. vex
    vex
    Mar 8, 2005
    2,888
    103
    London, Home Counties & North West
    +261
    Looks like both of those are CAI approved.
    As a double check have a look here http://www.cai.org.uk/asp/bmaerials.asp for others.
    Personally I like the Televes ones, but that because they are the only ones I have used.
    Also be aware you need a wideband one, not the grouped version mentioned on the site you have listed.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
  4. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Not necessarily. In some areas a grouped aerial will give better results. I suggest you buy from a local CAI installer and take his advice on what type would be best for you.
  5. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Imagine you buy a grouped aerial and they expand the channels into frequencies outside that group, its happened before. ;)
