What about this setup? (help please!)
J
John_l
Hello everyone,
This is my first post. I've been doing some researching around the net for about 3 weeks now. I was wondering if I could get some opinions on this setup.
The room I will have this setup in will be about 14 ft X 12 ft.
Amp/Receiver - Denon AVR-2802
Mains - B&W 601 S3
Centre - B&W LCR 60 S3
Rears - B&W 600 S3
I will hold off on buying a sub-woofer until I have settled into a 5.0 setup.
I will be using the setup as 60% DVDs and 40% music. I think the speakers and receiver will produce enough volume for the room. If someone could confirm this I would be greatful.
Also, are these speakers and reciever a good combination? Also is the receiver overkill for the speakers or vice-versa? These speakers/receiver meet my budget nicely. Am I getting good bang for my bucks with this choice.
Thankyou in advance for any advice that anyone has. I actually trust the opinions of people in forums like these much more that I would trust what you average salesman says.
Regards,
John
S
StJonno
i have a 2802 and im really happy with it, ive not heard anyone say a bad word about this range of receivers
ReTrO
If your budget will stretch run a second pair of 601's for the surrounds. This way you will get a more balanced sound field. Then it may be worth looking at a 3rd rear surround using a 601 also.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
