What about the Tannoy Revolution 15 sub?
Discussion in 'Subwoofers' started by JIT, Apr 18, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    Is this sub worth having to match my Revolution range or should I just go for another make? Would a sub from another manufacturer (not Tannoy) sound ok with my Tannoy Revolution R3's, R1's and RC?
  2. robh2002
    robh2002
    Mar 7, 2002
    367
    28
    Sheffield
    +28
    Having looked at the Tannoy web site, it doesn't look like a great sub to me (-6Db at 25Hz - amongst other specifications). Depending on the price, I'd say there are plenty of other potentially better subs out there.
    I do not believe that it is that so important to match subs with their respecive manufacturers speakers. The frequencies that a subs output are too low to be of any importance compared to obtaining the same character between L/R and centre speakers. What is far more important is how a subs will allow you to blend the frequency response to your main speakers better than others - with RELs generally being regarded as one of the best.
    Listen to a number of subs - then decide! I went through about 10 subs before choosing.
    Rob.
