what a/v amplifier? yamaha or sony
Discussion in 'AV Receivers & Amplifiers' started by theof, Dec 14, 2004.
Tags:
  1. theof
    theof
    HI Everyone.
    I'm thinking of buing one of the following amps. Yamaha RXV350,(5.1), Yamaha RXV 450(6.1), or Sony 597(6.1). I have a Sony DVD/SACD DVPNS 700 player, A Sony minidisk deck and i'm currently using an.....hmm...well,an antique amp. by sony. i'm listening mostly to jazz and movie soundtracks and i just love treble.Which one of the following models you think will have better sound quality and better responce to higher frequencies? thanks!!!!
  2. Poolsharkie69
    Poolsharkie69
    Well from my experience I find that Yamaha tends to be better with movies than music. I listen to alot fo music but its alternative with lots of bass. I had a sony before I went to the yamaha 640 then to the 1500 i have now. U didn't mention what speakers u will be using with those amps. I find Yamaha does an excellent job for my music tastes but like I said..more bass the better.
  3. theof
    theof
    well you're right!! i did forget to mention the speakers. Pair of pioneer 80w. (for now at least.)thanks!!!!!
  4. Poolsharkie69
    Poolsharkie69
    Are u able to take your speakers to the shop and have a listen to them on those amps. Thats the best way for your ears to make its decision?
  5. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    Forget the Sony STR-DE series, IMO they lack substance and power. Can you stretch to an STR-DB795 ? - far superior and only £30-40 more if you shop around.
