jenam93
Been slacking on the taking pictures front recently, partly because I know we have a hideous mess of photos dating back 10 years or so strewn across 3 laptops and a couple of hard drives.
As such I decided to try and finally organise them all and start removing ones that are not needed.
Several hours later I think I have all my photos consolidated onto 1 external drive, some 25,000 or more images across 400 or so folders/subfolders
Now I know there are multiple copies of some images, but I also found many files with the same name that are actually different pictures, i.e. the numbering got reset or multiple cameras using the same format.
So what I would like to do is find and use a tool that will search through my external drive and do 2 things. First, rename each file based on EXIF date of picture taken combined with the image name. Second, place the renamed file into a folder structure such as Year then Month e.g.
2012
11
12
2013
01
02
etc.
I will then go through the images with the Mrs and we will start removing ones we do not really need/want and we can then either add additional metadata for events like holidays/birthdays or do further subfolders to denote these events.
While there are tools out there that seem to be able to do this, has anyone here actually used one for this purpose? If so, which one did you use?
Or should I just be doing something completely different!
Many thanks in advance for you input
Jon
2012
11
12
2013
01
02
etc.
Jon
