Question What 75" TV Should I buy?
Discussion in 'What Is The Best TV For You?' started by gator24765, Jul 21, 2018.
Tags:
  1. gator24765
    gator24765
    Jul 21, 2018
    Texas
    I am in the market for a 75" TV. I am not looking for something over the top but nothing extremely cheap..
    Based on sales going on now, I have narrowed it down to these three:
    Currently I can buy the LG for $1298, the Phillips for $1275 and the Vizio for $1380
    LG 75UK6570PUB
    LG 75UK6570PUB: 75 Inch Class 4K HDR Smart LED UHD TV w/ AI ThinQ® | LG USA
    Vizio E75-E3
    VIZIO
    Phillips 75PFL6601
    Buy the Philips 6000 series Smart Ultra HDTV 75PFL6601/F7 6000 series Smart Ultra HDTV
    Thanks for the input
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Unless you need wide viewing angles probably the Vizio is the far better option. If you need wide viewing angles then maybe the LG is a better option but it will have worse overall picture quality. The Sony 70" X690E is probably a better option if you need those wider viewing angles.
    The Philips is unknown, to me at least.
