what 480p televisions in UK?
Discussion in 'General TV Discussions Forum' started by tfraser, Jul 2, 2001.
  1. tfraser
    tfraser
    Does anyone know of 480p televisions available in the UK and if so, what models and prices?
    Will most of these be 100htz?
  2. hudson806
    hudson806
    The Loewe Aconda does 480p. Sorta:
    First, there's the optional VGA socket, which will accept a 480p RGBHV image from a HTPC or DVD player with a VGA output, such as the Skyworth 1050.
    Apparently, it will also accept 480p at 50Hz and 60Hz through one of the SCART sockets. Dunno if its RGB or Component, though, but I suspect its RGB progressive.
    The Loewe Aconda is priced at about 1900STG or 2600-2800 Irish Punts, excluding stand, which will set you back another 300STG or 450IEP in Ireland.
    Subjectively speaking, its the best television available, bar none. Nothing even comes close (Although, I've not seen the Metz Artos in action)
