What 32" widescreen ?
Discussion in 'General TV Discussions Forum' started by Jock, Nov 27, 2001.
  1. Jock
    Jock
    I am hoping to but a new 32" widescreen before Xmas and had virtually decided upon a Panasonic TX-32PK25 but an earlier post about this TV only gave 1 response which was advising me against it.
    Can anyone recommend a 32" widescreen that they have and are perfectly happy with ?
    Is 100Hz worth it ?
    I don't need dolby sound as I will be connecting to an existing Home Cinema set-up, but would prefer a set supplied with a closed cabinet (to keep kids fingers away from DVD,Video and Sky box).
    Any recommendations would be much appreciated,
    Thanks,
    Jock :confused:
  2. Doubledoom
    Doubledoom
    There are enough posts about 100hz vs 50hz to keep you going for a while.
    You don't say your budget, which is probably the most important thing.
    BTW, my neighbour had 3 Panasonic TX-32PK25 and they all went back with faults. He is now on a Sony 100hz set (not sure of model)
