What 32" from ARGOS or COMET
Discussion in 'General TV Discussions Forum' started by anddon, Mar 20, 2006.
  1. anddon
    anddon
    Mar 8, 2006
    11
    Hi guys, i need some opinions quickly.
    i have vouchers for £550 that can only be used in the stores mentioned above, adding to the value is not an option for me at the moment. so i have decided to go for a 32" CRT Widescreen. but there are so many there, i don't know how to choose.. i will list some below and hopefully you guys can make some suggestions..
    PHILIPS - 32PW6520 or 32PW6720D/05
    TOSHIBA - 32Z53B
    HITACHI - C32W460
    SAMSUNG - WS32A116DSXXEU or WS32Z306VB
    JVC - AV32T5SK.
    sorry about the list, i think i got all the available ones. i have argued with the insurance companie and i can only purchase from these stores...
    any ideas guys ?????
  2. KAKU
    KAKU
    Go For A Toshiba Or A Phillips Have Had A Look At Both Of Them Superfine Sets Make Sure The Boxes Are Properly Stapled No Tapes On The Boxes Could Be Refurbs
  3. anddon
    anddon
    Mar 8, 2006
    11
    i forgot about this one too TOSHIBA 32YT56..
    is right to say this is a better model than the other TOSHIBA mentioned above..
  4. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    No, definitely not...the 32Z53B is Toshiba designed and manufactured. the 32YT56 is a "Bought-in" Vestel chassis and vastly inferior.
  5. bryfly
    bryfly
    Jan 15, 2006
    206
    28
    +51
    I would advise against this model, had 2 in quick succession both returned for faults, now have a sony, if you search on this forum for 32yt56 or 28yt56, you will see some of the comments............
  6. ANGUZ
    ANGUZ
    Mar 2, 2006
    383
    Boro
    +13
    I would avoid the Samsung WS32Z306VB, or at least read all the threads on it on here, sadly I didnt read em till after I`d bought one.
    Also follow KaKa`s advice, check the box, as Currys pulled a fast one on me and sold me a used or ex display TV as a new, and then tried to fob me off with discount.
  7. anddon
    anddon
    Mar 8, 2006
    11
    thanks guys for your replies...
    i am thinking along the lines of the philips 32pw6720d/05 - would this be a good choice ?
  8. olie055
    olie055
    When You will have some problem with Phillips, You cant pay for repair, thats problem of Phillips, it`s cheaper to buy new TV... Let`s make things better :D I`m going to buy toshiba 53 now, I hope it will be ok, I like toshiba... And is it true, with that 53 and 56? Thank You...
  9. GBDG1
    GBDG1
    Feb 5, 2006
    7,447
    +1,260
    Why don't you sell the vouchers and buy a one second hand. You can pick up a great quality CRT for around £200. pocket the £300. If you are keen on CRT then now is the perfect time to be buying second hand, you'd almost be mad to buy new. People who are upgrading to flat screen and have nothing to do with their old CRT's.
  10. davt99
    davt99
    Jan 19, 2006
    23
    I have had a WS32Z306VB and its great!
