What 26inch would you guys recommend ?
Discussion in 'LCD & LED LCD TVs Forum' started by slowpoke, Jul 11, 2005.
Tags:
  1. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    Not for PC viewing, just for watching TV. It has to be HD ready and as cheap as possible. I know Im asking alot but your input would be much appreciated
  2. SIDEARM
    SIDEARM
    How cheap is cheap. Can you give us an upper limit?
  3. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    £700 to £800
  4. Tony_R
    Tony_R
  5. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    its a minefield out there!! hi jack all you want!
  6. aj_walters
    aj_walters
    Jan 26, 2005
    53
    I have the PHILIPS 26PF5520D, first LCD TV, I'm very impressed with it. have used LCD monitors before on my PC and been generally disappointed, but this TV has won me over completely.
    Hope this helps
  7. supernova
    supernova
    Apr 28, 2005
    14
    aj
    I am thinking of buying the PHILIPS 26PF5520D, but there appears to be a lack of reviews or comment (on this site).
    I have had a demo of it and was impressed. The PQ was not far off the Panasonic LXD500 and I prefered the 26PF5520D to the 26PF7520D in some instances as Pixel Plus was more jagged around the edges!
    I was wondering if you have linked it up to a pc? I plan to use it for 50% of the time for Windows MCE viewing.
    Also, the manual says 1024 * 768 @ 60Hz is the max resolution. How does this look and can you view it easily from a distance?
    Are higher resolutions possible with Powerstrip or is this the limit of the screen with PC Input (DVI)?
    Otherwise do you have any general observations on PQ, sound, menu navigation etc....
    Cheers :)
    p.s. Can you recommend a wall bracket for this lcd?
  8. slowpoke
    slowpoke
    Jul 11, 2005
    1,091
    41
    Maidenhead
    +18
    after reading the thread on the samsung whoch is HD ready and very cheap on web electrical sI wthink i will get this for the upcoming footy season!! Cmon you SPURRRRRRRRRRRRRRSSSSSSSSSSS!!!!
  9. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Richer Sounds are doing the Sharp26GA3E for £799.00.
  10. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Soon to be replaced by the GA7 - specifically for PAL (625 lines) SD (standard def) resolution.
    Should be had for at least another £100 less online shortly, if not already.
    My personal pref would be the JVC LT26C50 - £700 or thereabouts.
    Check www.pricerunner.co.uk or www.dealtime.co.uk for the best price. I think it was the latter that I saw the JVC for just over £700 on.
  11. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    Misco do a 26in videoseven model or a newer 27inch version for £528 + £8.50 del
    if you sign up for a www.quidco.com account you should get 5% off.
    or use the jlewis link and get 4% off any 26inch they offer that fits your needs
