Wharfedale xarus series speakers - where can I buy them? UK
Discussion in 'Home Cinema Speakers' started by philmckibben, Jun 9, 2009.
  1. philmckibben
    philmckibben
    Jun 9, 2009
    5
    3
    Hi there, I have recently bought the Wharfedale Xarus 5000 speakers...great pair they are. But I want to finish my surround sound and buy the xarus centre speaker along with two xarus 2000. The problem is after searching through many websites and speaking to retailers, I cannot find where to buy them. Has anyone bought these speakers or know where to get them? Thanks
  2. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,147
    +4,167
    Hughes Direct is the only place I know of that has the Xarus 5000. If you buy them on Amazon, they are listed at £150 each; though you are still purchasing from Hughes. However, if you go to Hughes Direct website, they are £449.
    Hughest Direct -
    Wharfedale XARUS5000-BLACK from Hughes Direct
    Amazon.UK -
    Wharfedale XARUS5000-BLACK Xarus Floor Standing: Amazon.co.uk: Electronics & Photo
    These are the only instance of this speaker that I have found. You can search either site for other Xarus models.
    If you search Google UK, you might find more at certain DJ websites. That's about all I can suggest.
    Steve/bluewizard
  3. philmckibben
    philmckibben
    Jun 9, 2009
    5
    3
    Thanks for the reply. I have searched now for a couple of days and cannot find the 1000,2000 etc. They are listed on the Wharefdale website so they exist, the only think I can think of is that the rest of the speakers aren't out yet.
  4. tudj
    tudj
    Oct 10, 2008
    554
    Manchester
    +83
    Your best bet would to be phone up Wharfedale and ask them, they should know :p
  5. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,147
    +4,167
    Yes, it wouldn't hurt to ask Wharfedale, and while you are asking them, inquire whether they are available for order. That is, in-stock at warehouses in the UK.
    If so you could go to virtually any Wharfedale dealer and have them order the speakers.
    BUT, once they are ordered, they are yours. I suspect no returns on a special order speakers.
    Just a thought.
    Steve/bluewizard
