Wharfedale SW150
Discussion in 'Subwoofers' started by dvdsubtitles, Aug 26, 2004.
  1. dvdsubtitles
    dvdsubtitles
    Hi guys,
    I've just read in What Hi-Fi? that the Wharfedale SW150 is brilliant value for money, and considering whether this sub would be suitable for my home cinema in the living room.
    Does anyone have any experience with it, and will it go well with my Mission M71s and a Pio VSX-D814 receiver? The room is 5m by 3.5m.
    Thanks in advance,
    Mat.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    Wharfedale have made some good subs in this catagory before and this one seems to have the basics covered. I can't quantify how good it might be because despite the fact that WHF have a 309 (which won the last budget test), they decided not to pop in that test :suicide:. I'm sure it will happen sooner or later.
  3. Anrasp
    Anrasp
    Nov 28, 2002
    69
    Malta
    ..can't seem to find it on the net :confused: anyone got a link ?
  4. Lostinapc
    Lostinapc
    what hifi only compares the sub to other new subs, not to older subs such as the ms309 which they previously have claimed to be the best...
  5. dvdsubtitles
    dvdsubtitles
    No, I can't seem to find it either. According to What Hi-Fi? its in the "Diamond 9" range. Can't really find any information about the Diamond 9 range either - perhaps its too new ??
    Mat
  6. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    The Diamond speakers at the front of that issue of WHF hadn't been released yet so it might be the same for the sub.
  7. dvdsubtitles
    dvdsubtitles
    Wharfedale have a 309? I can't find that on the net either. Are you sure you don't mean the Mordaunt-Short 309?
    Mat
  8. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    Yes and what I meant is that WHF magazine still have the 309 we (MS) sent them last time when it won. That it didn't go head to head this time means I have nothing to relate the Whafedales performance to.
  9. WILD9
    WILD9
    Mar 12, 2003
    156
    Cheltenham
    +6
    WHF = What Hi-Fi not Whafedale
  10. dvdsubtitles
    dvdsubtitles
    Ah, I got it. Would the ms309 work well with my mission m71s and Pio D814 reciever?
    Mat
  11. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    I hope so. I'm probably going to kick myself later for saying this but you'd do interested parties a big favour if you could test both.
  12. dvdsubtitles
    dvdsubtitles
    It would probably be very difficult for me to compare the two in terms of sound quality as I'm profoundly deaf. However, subs do make a huge difference to me as I can feel the effects.
    What I'm trying to establish here is whether either of these subs would be a suitable match for my system based on the type of speakers and amp I have. It's very difficult for me to go and test several subs because of my hearing, which is why I'm asking peoples' opinions here.
    Thanks,
    Mat.
  13. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    Both of these subs should work happily with speakers in the £150-350 (per pair) as they have good respose between 25 and 80hz. The 309 has tweaky features like the notch filter on its side (allowing for better room setup) and the ally driver looks quite special.
  14. dvdsubtitles
    dvdsubtitles
    Thanks :smashin:
  15. dvdsubtitles
    dvdsubtitles
    Finally found it. Seems that the new Diamond 9 range is due to be released in Oct, which is probably why it hasn't appeared on the Net till now.
    Here it is:
    http://www.hifibitz.co.uk/product.asp?id=3442
    Cheers,
    Mat.
  16. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    yeah, I very interested in seeing what sub between these two is the better...its looking more likely that I'll be upgrading my sub....
    edit - the only issue I seem to have is that botgh of these sub only go down to 35Hz - whereas my Eltax claims it can do down to 30Hz, but with my Avia test disk, I've heard audioble tones at 32Hz...
    so, would i actually potenially lose out by buying one of these newer budget subs..?
  17. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
  18. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    You have to be very careful not to get too hung up on manufacturer's specs as most of them could well have been written by a government spin doctor for all the use they are. There are many ways of measuring depth, most of which are unduly flattering to the sub manufacturer but of equal importance is the amount of distortion produced as there is no point reproducing sounds further down the frequency range if it all just audible distortion.
    Unfortunately accurate, deep sub bass cannot be reproduced cheaply and most of the budget subs are a compromise in one way or another.
    As of the end of October the new "economy" SVS will play cleanly down to 20Hz for £350 and I very much doubt whether any other sub can get any where that level of performance for the price.
  19. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    cheers Ian - would that include delivery..?? as I'm aware that they're only imported from the us...
    cheers
  20. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    It includes delivery and all taxes and could well be the subwoofer bargain of the decade if the performance lives up to it's paper spec.
    Either way I'll tell you all as soon as mine lands
  21. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
  22. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    If I keep my 309 i can do a comparative test between my baby SVS (when it arrives) and the 309 :devil: Now i wonder which should win :D
  23. MS-Yam
    MS-Yam
    Aug 12, 2004
    235
    16
    Dfour, which model is the SVS you are waiting for? I have been reading a lot about SVS subs and, if it is not much more than the 309 or XLS200, I may be tempted! How much is it?
  24. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    It will be this little monster in black :D I am guessing it will be about $540 + import taxes + Bax's fee.
  25. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    He means this ,about £370 ish all in.
    [​IMG]
  26. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    Just gonna have to have it delivered to my flat when im off work and then paint the driver silver so Ms. Dfour wont notice:devil: Then again she didntnotice/never said anything about my rotel amps breeding :D
