wharfedale Sub "Stereo"
Discussion in 'Subwoofers' started by dan76n, Nov 25, 2004.
  1. dan76n
    dan76n
    May 12, 2003
    88
    australia
    Hi all,
    My Wharfdale sub has stereo inputs on it, RCA not speaker wire. why is this
  2. aliflack
    aliflack
    Mar 19, 2004
    238
    16
    so that you can feed it a low level signal...speaker wire connections are for high level connections.
    From what others have said, not many people use the high-level connection, and manufacturers are beginning to not bother including them...
  3. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    It is so you can run the subwoofer off the stereo pre-outs on an amp if the amp has them. The sub will convert the stereo signal to mono internally. Some subs have low level inputs and outputs so can be placed between the pre-amp and power amp, occasionally these go through a built in crossover too.
