Wharfedale moviestar 60+
Discussion in 'Home Cinema Speakers' started by samsuka, Nov 7, 2003.
  1. samsuka
    samsuka
    Oct 29, 2003
    20
    3
    :hiya: (just wanted to use that)
    I have been offered these surround sound speakers for £100, are they any good for the money?
    I am only just starting to set up an av system and can't spend any money on improving my setup too much until i have my wedding out of the way.
    I plan to pair them up with a Sony STRDB790 receiver for £250
    Any help would be much appreciated
    Sam
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Hi samsuka
    My brother brought two of these sets 60+ from superfi brand new for 56 quid each they may still have some left ,its worth ringing round a few superfi branches. He brought his from the derby branch.
    The speakers are okay well made and for the price cant grumble.
    He used his on a budget sony receiver and had no trouble driving them even though they are 4ohm speakers.
    Cheers Gonzo.
  3. samsuka
    samsuka
    Oct 29, 2003
    20
    3
    Jip, Superfi want to charge me £100 (in London if that makes a difference), cheers for the feedback they should do the job until i can afford something decent.
    How many ohms should they have or is good ( am a complete novice). Does only have 4ohms make them bad? With a good amp will can i make them better?
    Learning a lot here!!
    Samsuka
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Hi Samsuka
    The impedance doesnt mean there a bad speaker it just means they take more power to drive efficiently.Being small speakers helps and as i said my bro had no problems running them on his budget sony receiver.
    Cheers Gonzo.
  5. samsuka
    samsuka
    Oct 29, 2003
    20
    3
    OK last question ;-)
    I am going to buy the Sony STRDB790 or the Yamaha RX-440RDS and put the Wharfedale Moviestar 60+ speakers on them http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1448 which are 4ohm but i also have some Denon (made by Mission) SCM50 http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/101 which are 6ohms which i was thinking about using as my main speakers as they are a little better (i think). Would this work or am i better to keep my setup all Wharfedale?
    Can i mix and match the ohms' on the speakers on my receiver?
    Thanks for any feedback
    Samsuka
  6. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Hi samsuka
    I would just use the movie star on its own, the yamaha amp has an impedance switch on the back that can be switched to 4 ohms but both amps will drive the 60+ ok.
    Cheers Gonzo.
