I've bought a set of Wharfedale Evo 4.4 along with a Denon AVC-X3700H. I'm really happy with the setup and they simply sound amazing in all volume ranges.
Unfortunately, I do experience an odd behaivour from time to time.
Setup (all new):
During low volume music, sometimes the tweeter on one of the speakers does not work at all. The tweeter on the other speaker does work as expected at the same time during the same song.
If I increase the volume, at a certain point the missbehaving speaker seems to have "breakthrough" and everything is back to normal. I can then decrease volume and the speakers are balanced again (both tweeters working the same way).
I've tested it by putting my ear close to both tweeters during the same song listening closely to the higher frequencies and switching quickly between both speakers.
Tests so far, without any success:
Hypotheses:
Has anyone experienced something like this? Any tips for what to test or do now? I'm running out of ideas.
Thanks a lot!
Setup (all new):
- Wharfedale Evo 4.4
- Denon AVC-X3700H
- 4mm (0.15") cables
- no bi-wiring/amping
- Music source: HDMI connected devices and Spotify Connect
- Checked correct cable connections (red/red, black/black)
- Disabled Audyssey and all other functions which control the music
- Disabled Eco mode
- Tested various input music sources and connection types to rule out any input problems
- Switched left/right connection of speakers at the amp (still the same speaker has problems, although less often)
Hypotheses:
- The affected speaker has a defect?
- The amp does mess up the signal
- Cable connection is not good enough (no banana plug connection)
- Speakers need more play-time
Thanks a lot!
